deRabes Posted February 6, 2012 Posted February 6, 2012 HiList I am trying to offset a sketch. It offsets fine in an outward direction i.e. it gets bigger. But I can't offset it smaller for some reason. The loop is closed and everything seems OK but..... Any help appreciated Quote
Jack_O'neill Posted February 6, 2012 Posted February 6, 2012 Without seeing the loop you are trying to offset, I can only guess that there's some part of it that would be self intersecting. Can you post a screen shot or the actual file? that would help. Quote
deRabes Posted February 6, 2012 Author Posted February 6, 2012 Sure thing. Its attached. Thanks BellowsPad Trim.ipt Quote
rkent Posted February 6, 2012 Posted February 6, 2012 You can erase the small radius and offset the two large arcs, draw the fillets back in. Quote
deRabes Posted February 6, 2012 Author Posted February 6, 2012 Thanks rkent. That worked a treat. Quote
JD Mather Posted February 6, 2012 Posted February 6, 2012 It offsets in either direction for me - as long as I don't try to go beyond where the fillet would be zero (or less). Quote
deRabes Posted February 7, 2012 Author Posted February 7, 2012 That was my problem. I assumed wrongly that it would adjust automatically. Thanks Quote
JD Mather Posted February 7, 2012 Posted February 7, 2012 What would that assumed adjustment look like? Can you manually sketch what you expected? Quote
deRabes Posted February 7, 2012 Author Posted February 7, 2012 I just thought the offset would close on the fillet until it became a corner and would continue decreasing on that basis I suppose. Quote
JD Mather Posted February 7, 2012 Posted February 7, 2012 The arc entity would have to be automatically erased by Inventor and the coincident constraints at the endpoints of the arcs transfered to the endpoints of the lines. Sounds like a wish-list item. http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794 Quote
