Hello ppl
I want to be able to store the pointer coordinates upon pressing left mouse button, while getdist is active.
I did something here:
(setq lcoo nil)
(while (getdist)
;if i take of this line it works similar to what I want ,but the prupose is to store points while getdistance active and left button is pressed. ( getdist have 2 points so at least i want to store 2 points)
With this line (while (getdist)  i get every second point???and not very sure about it.
 (setq value (grread))
 (if (= (car value) 3)
   (setq ptc (cadr value))
 (setq lcoo (append lcoo (list ptc)))
thanks
;; Get Points  -  Lee Mac
;; Returns a list of UCS points selected by the user
(defun LM:GetPoints ( / l p )
   (if (car (setq l (list (getpoint "\nFirst Point: "))))
       (while (setq p (getpoint "\nNext Point <Done>: " (car l)))
           (mapcar
              '(lambda ( a b ) (grdraw a b 3 1))
               (setq l (cons p l))
               (cdr l)
   (redraw) (reverse l)
Thanks for reply Lee
I wonder if this is possible during getdist. Getdist required two points i want to save them while getdist is active.
The above code is doing essentially the same thing.
To get the distance between successive points from the returned list:
(setq lst (LM:GetPoints))
(mapcar 'distance lst (cdr lst))
I'm gonna give it last shot...different way...
Can I find out the points coordinates that were picked when getdist was active...(2points).I mean i want a distance and points coordinates.
briefly how to see points of getdist?
I thought you would've put 2 and 2 togther, just use getpoint then distance.
(if
   (and
       (setq p1 (getpoint "\nSpecify First Point: "))
       (setq p2 (getpoint "\nSpecify Second Point: " p1))
   (distance p1 p2)
You can have a problem if 3D points are involved. Neither ( getpoint ) of ( distance ) have a built in 2D filters. -David
