tdole Posted October 22, 2008 Posted October 22, 2008 Out of nowhere, some of the commands have stopped working on my 2006. Double clicking text no longer brings up the edit box with both single line & multi line text. I can access it through edit>text command though I can only edit properties in the props box, not in the drop down menus up top. Also, the delete key on my keyboard has stopped working when erasing (I can still use erase) As these have all happened at once I'm assuming there is a single setting that has de-activated this. Hope someone can assist as I'm really set in my ways and can't stand doing commands twice!!!lol Quote
nocturne00 Posted October 23, 2008 Posted October 23, 2008 check your PICKFIRST variable, it may be the culprit. set it to "1" Quote
tdole Posted October 23, 2008 Author Posted October 23, 2008 Sensational, thanks so much. Question is, what would have reset it to 0? Good to know how to fix it, better to know how to avoid it happening again! Once again, thanks so much. Quote
nocturne00 Posted October 23, 2008 Posted October 23, 2008 This may have happened when you were trying to rotate viewports. I answered a similar thread like this, ill try to find the link to give you a bit of an idea how it happened Quote
nocturne00 Posted October 23, 2008 Posted October 23, 2008 This may answer your question http://www.cadtutor.net/forum/showthread.php?t=27815[url=http://www.cadtutor.net/forum/showthread.php?t=27815&highlight=MVsetup][/url] Quote
User Posted December 17, 2008 Posted December 17, 2008 Wow! This is the greatest thread in the world. I have been screaming at my computer all day. Delete button stopped working, everything was crap. Felt like I was being forced to learn a new program. This "mvsetup" command should come with a warning label eh? Thanks! Quote
