deRabes Posted February 8, 2012 Posted February 8, 2012 Hi I have a cylindrical part with holes to be drilled around the circumference. I have a work plane set at the front and at the back and want to position one at about 50 degrees off the front work plane. Can someone run me through the process involved? Thanks again in advance New.ipt Quote
JD Mather Posted February 9, 2012 Posted February 9, 2012 Your WorkAxis1 is a duplication of the Z axis and not needed. Your hole sketches are not constrained and too much work (could do with one sketch). To create angled workplane create sketch on XY plane with line at desired angle to desired plane location. Exit sketch. Create workplane at endpoint of angled line by selecting the endpoint and the line. Quote
deRabes Posted February 9, 2012 Author Posted February 9, 2012 All taken on board. Will do Thanks Quote
