madonthemike Posted February 9, 2012 Posted February 9, 2012 Hi, We have a menu at work - that was developed by some one who no works there, basically it has a drop down for selecting scale (has both imperial & metric scales) and once the scale is selected it sets a value and symbols are scaled accordingly when they are dropped in. It works fine but sometimes we will get a couple of drawings where say its is an imperial drawing, so I select the imperial scale but when the symbol is inserted it is tiny , and I have to scale it up by 25.4 to make it actual size. So if its an 1/8th scale drawing I would usually choose 1/8th on the menu and work from there, but on certain drawings it doesnt work - so I choose the nearest metric scale 1:100 in this case and it works. 1. Why does this happen? I would like to know what variables controls whether a drawing is imperial or metric or is there even such a thing? 2. Im busy making a menu to improve my productivity, but a big part of my setup is setting the scale, how should I implement this so it works on all dwgs? Thanks Quote
SunnyTurtle Posted February 9, 2012 Posted February 9, 2012 -DWGUNITS is something we have a problem with when using metres and mm. but part i can't understand your problem and i don't wish to delive in to imperial at this time to Busy. but im sure somone who uses imperial will be happy to help Quote
eldon Posted February 9, 2012 Posted February 9, 2012 The system variable MEASUREMENT is set at 1 for metric and 0 for imperial Quote
asos2000 Posted February 9, 2012 Posted February 9, 2012 I think its better to add a button to do all the changes you want for example -UNITES INSUNITES MEASUREMENT ... etc Quote
SLW210 Posted February 9, 2012 Posted February 9, 2012 What method do you use to determine if a drawing is Metric or Imperial? How are you determining the scale? Quote
madonthemike Posted February 10, 2012 Author Posted February 10, 2012 What method do you use to determine if a drawing is Metric or Imperial? How are you determining the scale? Well most of the time the drawings I get are dimensioned to a specific unit so its not so hard to figure out, sometimes I sometimes I measure a known distance like a door or parking space and can figure out from there what the units are. Is there a clear cut way of telling whether a dwg is imperial or metric without having to figure out? If I were to create a library of symbols (a dwg for each symbol) what kind of template should these symbols be in (Metric/Imperial)? So that once I set the scale they symbols are the right scale without having to scale up or down to the right size? Quote
