Good Day
Have a Drawing that has symbol blocks in it.
Blocks are not inserted into drawing - so no instances.
How does one view the list of blocks in the current drawing.
Any assistance welcome
"This is probably a basic routine"
Thanks in Advance
Try this function
You can put DataSource property of ListBox
as result of this function:
      Public Function ListBlocks() As List(Of String)
           Dim db As Database = HostApplicationServices.WorkingDatabase
           Dim blocks As New List(Of String)
           Try
               Dim tr As Transaction = db.TransactionManager.StartTransaction()
               Using tr
                   Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                   For Each id As ObjectId In bt
                       Dim btr As BlockTableRecord = DirectCast(tr.GetObject(id, OpenMode.ForRead), BlockTableRecord)
                       If Not btr.IsAnonymous And Not btr.IsLayout Then
                           blocks.Add(btr.Name)
                       End If
                   Next
               End Using
           Catch ex As System.Exception
               Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message & vbCr & ex.StackTrace)
               Return Nothing
           End Try
           Return blocks
       End Function
On load in your form:
ListBox1.DataSource=ListBlocks
Not tested
~'J'~
