Hello!
Using array command I inserted blocks. Than I made a selection set of those blocks.Now I want to put dimensions in between the insertion points of those blocks.
1. How to get info whats in selection set.
2. can I use vla-dump on selection set?
Appreciate your help
You will need to iterate through the entities in the Selection Set and either query the DXF data using entget, or access the properties / methods of the associated VLA-Object by converting the entity to a VLA-Object using vlax-ename->vla-object.
There are many ways to iterate through a Selection Set, here are just a few (each will print the entity types of each entity in the set):
(defun c:test1 ( / e i s )
   (if (setq s (ssget))
       (repeat (setq i (sslength s))
           (print (cdr (assoc 0 (entget (ssname s (setq i (1- i)))))))
(defun c:test2 ( / e i s )
           (setq i -1)
           (while (setq e (ssname s (setq i (1+ i))))
               (print (cdr (assoc 0 (entget e))))
(defun c:test3 ( / e i s )
           (setq i 0)
           (repeat (sslength s)
               (print (cdr (assoc 0 (entget (ssname s i)))))
               (setq i (1+ i))
(defun c:test4 ( / e s )
       (foreach e (mapcar 'cadr (ssnamex s))
           (if (eq 'ENAME (type e))
(defun c:test5 ( / e s )
       (while (setq e (ssname s 0))
           (ssdel e s)
(defun c:test6 ( / e i l s )
           (setq i 0
                 l (sslength s)
           (while (< i l)
               (setq i (1+ i))
  • 4 weeks later...
Hello it's been a while,
Using array command I inserted blocks. Than I made one block out of these blocks.Now I want to put dimensions in between the insertion points of those blocks.
Whats is a best and easiest way getting insertion points of these blocks.
Visual lisp or autolisp?
If I've understood that each block is now nested within the main block, you have two options:
1) Iterate over the Objects in the Block Definition using vlax-for on the VLA Block Object in the Block Collection.
2) Iterate over the Objects in the Block Definition using entnext on the Block Entity in the Block Table.
When you have the insertion points of the Block subentities, you will need to transform these points (possibly using a transformation matrix) so that they are relative to the Block Reference (Insert), accounting for rotation and scaling (since the points will be defined relative to the Block Definition at 1:1 scale and zero rotation, with base point at the origin).
thanks for instant reply
Hello
Is it possible to have an example of vlax-for usage? lets say to see the insertion points of the nested blocks within a block.
will continue my reasearch about vlax-for for now
This isn't a short & simple bit of code, so if you wish for me to write the code for you, I would welcome you to contact me through my site and we can discuss it further.
Lee
With all the respect to you Lee, are you saying that it's time to pay for your services?
If there is a guy on internet, who deserved a donation it's you...but I would appreciate a more direct "you know what".
Thank you SuperLee
Thank you SuperLee
Thank you for your kind words Qonfire.
Indeed, I would need to charge a fee to cover the time required to construct the code.
