What is the easiest way to add a radius to two lines that for an obtuse angle? Example: I want to add a 1" Radius to two lines that are at 156 degrees.
Thank you!
Command:
FILLET
Current settings: Mode = TRIM, Radius = 0
Select first object or [undo/Polyline/Radius/Trim/Multiple]: R
Specify fillet radius : 1
The circle command tan,tan,radius works too.
