At the moment I am trying to work out how to find out if any of the objects in my selection set contain a certain value. The value, in this case, that I am looking for is a Z coordinate.
Obviously a negative value is also a coordinate, but I think I should be able to handle that part of the code, once I have worked out how exactly to ask if any items have a Z value that is not exactly 0.
It think using elevation I should be almost there. The problem is just getting a list of all the objects in the selection set.
It all depends on object type. You will probably need to "feed" the selection set ents one at a time through a SELECT CASE ent.OBJECTNAME and then query the z once you know the object type. I hope I am making sense.
