concave fillet:how to do using fillet cmd?
Hi guy,
How do I create a concave fillet in AC2012?
Usually, when I try to fillet one edge it creates a convex fillet.
and if I want it to be concave instead?
Thanks,
Stefano
The only way I can think of at the moment is to draw a CIRCLE with the TTR (Tangent/Tangent/Radius) option then TRIM as needed.
Hi nestly, thanks for your reply.
I see what you mean, and in case I'm working with a solid edge how can I workaround this?
Same concept, you just have to create a solid you can "subtract" from your main part... or create a surface you can use to "slice" the corner, or as in the video below, use PRESSPULL to do both in one operation.
thanks mate!
that's what I was really looking for:)
you gave to me a really great explanations, I really appreciate your help
Stefano.
