Sometimes when using the trim command it will completely freeze on me and I have to force a close. This only happens though then I try to trim a line or lines (qty of objects does not matter) by windowing the object. If the click the line, its ok. But if I were to window it... Bam... Frozen! and it wont come back. I went to lunch and back and still locked up.
anyone else experience a similar issue and found a resolution?
BTW I open the task manager and the memory that CAD is using in nothing substantial enough to create an issue to freeze
I have had a similar problem a few years back.
While using the TRIM command are you slecting any parameters before trimming the object(s)?
Is this happening in only a particular drawing? You might get some improvement by doing a good purge. I used to have this happen to me now and then when I was on ver. 2007. It seems to be a memory addressing problem and dumping a lot of the unused stuff out of your drawing through a purge might help. Then run Audit on it too.
Once a drawing that did this got corrupted and I had to call in some magicians to recover it for me.
nope, totally random, any drawing. I have plenty of ram so i dont wanna says its the problem.
Well, I dunno then. Bloated scale lists? Maybe they are all too fat?;) How much ram is on your vid card? You really need to have at least as much as AutoCad suggests.
I'm kinda spittin' into the wind here. It's been a while since I had to deal with this issue. Usually somebody that actually knows how to fix stuff pops in and takes over for me.:(:lol: I don't wanna wast your time with guesses.
I echo the purge idea. All sorts of stuff collects, especially in a big drawing. I routinely get drawings from customers that are 8-10 mb. Quick purge usually cuts them in half or less.
I would say it is a graphics card or driver problem since it is only associated with windowing.
