emarshall Posted February 15, 2012 Posted February 15, 2012 I recently upgraded to a Windows 7 64-bit machine, and after downloading and installing the VBA module for Civil 2011 and running a routine, this error came up "(Compile error: Function or interface marked as restricted, or the function uses an Automation type not supported in Visual Basic)" The line of code is txtSelectTab = ShowFileOpenDialog("*.txt", "Tab delimited Ascii", "Select input file:", "C:\", ThisDrawing.HWND) with HWND highlighted, so i'm assuming that's the problem. I'm not much of a coder, I didn't write this particular application, but I would like to fix it if anyone can help. Thanks. Quote
