Hogfan Posted February 16, 2012 Posted February 16, 2012 I just got this error message this morning when trying to use a simple AC tool on a drawing-"acimpression file not found", When i RC on toolbars and goto customize i get that error. I guess the first error was Unknown Command "breakline". I use this command all the time, it said that the acipression file had been removed or renamed and that i would need to reload it. Type cuiload at command line. When i do this it goes to some cui files, but that paticular file is not listed. Confused on this.. All the other commands seem to be working but this one... Any thoughts on this?? Quote
ReMark Posted February 16, 2012 Posted February 16, 2012 Do you have AutoDesk Impression installed on your computer? Quote
Hogfan Posted February 16, 2012 Author Posted February 16, 2012 I thought i did, but apparently not or something happened to it. Does it need that to work, if so is it on the AC install disc or downloaded from another source.. Quote
BlackBox Posted February 16, 2012 Posted February 16, 2012 Either your Main CUI(x) or Enterprise CUI(x) (if you have one of those) is referencing the ACIMPRESSION.CUI(x) as a Partial CUI(x), even though one is not found within your current Support File Search Paths (SFSP). *IF* you have Impression installed, simply locate the CUI(x) file, and attach the CUI(x) file as Partial, otherwise simply remove the Partial reference in the Main/Enterprise CUI(x). HTH Quote
SLW210 Posted February 16, 2012 Posted February 16, 2012 See if this works.. On the command line, enter CUI. In the Customize User Interface dialog box, under All Customization Files, click Partial CUI Files to expand the list. Select ACIMPRESSION (Unresolved), and then right-click. On the shortcut menu, click Unload CUI File. Quote
Hogfan Posted February 16, 2012 Author Posted February 16, 2012 (edited) I understand what your saying, but when i get to cui file, then main, then partial and i RC on partial, upload cui file, nothing happens, screen blinks once or twice and nothing... Command: breakline Unknown command "BREAKLINE". Press F1 for help. This is how it starts, what can i do, The little icon on the toolbar has changed to a ? symbol. like it doesnt know where it's at.... Edited February 16, 2012 by Hogfan added information Quote
SLW210 Posted February 16, 2012 Posted February 16, 2012 Did you try to unload as described above? Sounds like something happened to your registry or you have a virus. Breakline is an express tool. Are any other express tools not working. Quote
Hogfan Posted February 16, 2012 Author Posted February 16, 2012 Looks like all my express tools are messed up!! I will try the unload command if that is what i need to do first? Quote
BlackBox Posted February 16, 2012 Posted February 16, 2012 Ummm... What reason was there for deleting my post, SLW...? Quote
Hogfan Posted February 16, 2012 Author Posted February 16, 2012 Well any suggestions on the express tools being all messed up, Can i reload them or what do i need to do? thanks in advance!! Quote
