The never ending story: Polyline export to file
Thx pBE. Does this mean that this routine that you wrote can be used with line, poly line, lw poly lines and 3D polyline, very nice that is exactly what i need?
Please if you can do a ;; around the lisp i could lean something. But i must say many thanks what you have done so far.
I still need the file to be "W" rite so no append to the file.
And another thing is that when i make a selection of Lines let we say 3 lines i need the coordinates in this manor to the file:
S X= Y= Z=
E X= Y= Z=
S X= Y= Z=
E X= Y= Z=
S X= Y= Z=
E X= Y= Z=
The way that you have done it with the poly lines, LW poly lines,3d poly lines ect. i just grate, But when it is lines that is selected the output to the file should be like the one mentioned over here.
Edited by elfert
  • Replies 48
  • pBe
    15
  • elfert
    11
  • Kapanther
    8
  • SolarPVDesigner
    4
  • 2 months later...
How can I add a column to include an "identifier" for which polyline the x,y coord comes from?
Fox example? could you add a column for the acad handle maybe? or a "count" as it moves through each polyline?
Thanks for your help!
Yes YOU can :)
This code feels like ages ago. I need to have look-see at the code i posted
Hang on....
Edited by pBe
Indeed.. Thanks for your help!
Will it look like this for every line?
[color=blue][b]B49F[/b][/color] at point X =14805.2190 Y= 4837.2547 Z= 0.0000
[color=blue][b]B49F [/b][/color]at point X =19030.0596 Y= 10922.8723 Z= 0.0000
or
[b][color=blue]B49F[/color][/b] at point X =14805.2190 Y= 4837.2547 Z= 0.0000
[color=white]_____[/color][color=black]at point  X =19030.0596 Y= 10922.8723 Z= 0.0000 [/color]
B49F at point X =14805.2190 Y= 4837.2547 Z= 0.0000
B49F at point X =19030.0596 Y= 10922.8723 Z= 0.0000
is fine
B49F,14805.2190,4837.2547,0.0000
B49F,19030.0596,10922.8723,0.0000
is better
No need to stop the handle
sounds like oyu got it
Gimme Gimme Gimme!!! hehe :notworthy:
thanks for your help!!
Hold your horses Kapanther :).
You do realize that the code wirtes to a specific file on a specific folder and drive letter. Do you want to maintain that?
Hehe I can modify as necessary.
Thanks for help
You have me waiting in suspense!
Thanks for help
You can modify the rest then
(defun c:vlplexport  (/ AT:GetVertices  _dxf theobj[b][color=blue]s[/color][/b] [b][color=blue]i [/color][/b]fn thelist  f)
     (defun AT:GetVertices  (e / p l)
           ;; Return point at each vertex of curve
           ;; e - curve to evaluate (Arc, Line, *Polyline, Spline)
           ;; Alan J. Thompson, 09.30.10
           (if e
                 (if (eq (setq p (vlax-curve-getEndParam e))
                         (fix p))
                       (repeat (setq p (1+ (fix p)))
                             (setq l    (cons (vlax-curve-getPointAtParam
                                                    e
                                                    (setq p    (1- p)))
                                              l))
                       (list (vlax-curve-getStartPoint e)
                             (vlax-curve-getEndPoint e))
     (defun _dxf (ent dx)(cdr (assoc dx (entget ent))))
     (prompt "\nSelect a [b][color=blue]Polyline/Lines for data export[/color][/b]: ")
[color=blue][b](if (and[/b][/color] (setq theobjs (ssget  '((0 . "*LINE"))))
        (not (vl-mkdir "c:/User"))
        (setq fn (open (setq f "c:/user/infile.txt") "w"))[b][color=blue])[/color][/b]
   [color=blue][b](progn
        (repeat (setq i (sslength theobjs))
[/b][/color]     (setq thelist (if (eq (_dxf (setq e (ssname [color=blue][b]theobjs (setq i (1- i))[/b][/color])) 0) "LINE")
                        (list (cons (_dxf e 5)(_dxf e 10))
                              (cons (_dxf e 5)(_dxf e 11)))
       (mapcar '(lambda (j)(cons (_dxf e 5) j))
                                  (AT:GetVertices e))))
         (foreach
                  itm  thelist
                 (write-line
                       (strcat (car itm) ","
                               (rtos (Cadr itm) 2 4)
                               (rtos (Caddr itm) 2 4)
                               (rtos (last itm) 2 4))
                       fn)
     (close fn)
     (startapp "notepad" f)
        )[b][color=blue](princ "\nNo Entities to process")
   )[/color][/b]
     (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport)
HTH
Edited by pBe
Updated for mulitple selection
So Kapanther, did it work for you? You have me waiting in suspense! :lol:
Yeah it worked!
Although I forgot this lisp only does it for one polyline. How hard is to do on multiple polylines?
Yeah it worked!
Its not really just for one polyline, as long as you keep selecting a valid entity (Line/Polyline/Lwpolyline) the program will continue. Also, take note that it overwrites the previous data whenever you run the program on another set of objects. the "W" argument for open does that.
Anyhoo. i updated the code for multiple selection mode.
 [/color][/b]
Nice work fella.
Works a treat!!!!!!
I owe you one.!
Nice work fella.
Works a treat!!!!!!
I owe you one.!
Good for you Kapanther, The way i see it. you owe this forum more than you do me. ;)
Glad i could help, Cheers
I'm running the routine by Alan J. Thompson, 09.30.10 but I need it to follow my UCS. Right now it's only working off WCS. I'm getting back into AutoLISP after a 15 year hiatus and trying to determine if I can get the "Tran" command to work for this.
Which code are you referring to SolarPVDesigner?
Guess he meant AT:GetVertices
No need to modify the function but instead apply trans on the result of the function
(setq _trans (lambda (pt) (trans pt 0 1)))
(setq ss (AT:GetVertices (car (entsel))))
(setq pts (mapcar '_trans ss));<-- translated point list
HTH
EDIT:Unless Alanjt decides to incorporate the trans within his sub ;)
Edited by pBe
