SolarPVDesigner Posted May 10, 2012 Posted May 10, 2012 (edited) (defun c:vlplexport (/ AT:GetVertices strnum theobj fn) (defun AT:GetVertices (e / p l) ;; Return point at each vertex of curve ;; e - curve to evaluate (Arc, Line, *Polyline, Spline) ;; Alan J. Thompson, 09.30.10 (if e (if (eq (setq p (vlax-curve-getEndParam e)) (fix p)) (repeat (setq p (1+ (fix p))) (setq l (cons (vlax-curve-getPointAtParam e (setq p (1- p))) l)) ) (list (vlax-curve-getStartPoint e) (vlax-curve-getEndPoint e)) ) ) ) (defun strnum (str val / p) (setq p " ") (repeat (- val (strlen str)) (setq p (strcat " " p))) (strcat str p)) (vl-mkdir "c:/autolisp") (prompt "\nSelect a Polyline: ") (while (setq theobj (ssget ":S:E" '((0 . "*LINE")))) (setq thelist (AT:GetVertices (setq e (ssname theobj 0)))) (setq fn (open "c:/autolisp/infile.txt" "w")) (redraw e 3) (foreach itm thelist (write-line (strcat " at point X =" (strnum (rtos (Car itm) 2 4) 10) "Y= " (strnum (rtos (Cadr itm) 2 4) 10) "Z= " (strnum (rtos (last itm) 2 4) 10)) fn) ) (close fn) )(vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport) (princ) ) Edited May 10, 2012 by SolarPVDesigner Quote
SolarPVDesigner Posted May 10, 2012 Posted May 10, 2012 (edited) Where would the following code be incorporated into the code above? (setq _trans (lambda (pt) (trans pt 0 1))) (setq ss (AT:GetVertices (car (entsel)))) (setq pts (mapcar '_trans ss));<-- translated point list Once I see it done I can grasp it and then look out world!! Thanks pBe and Lee Mac Thanks, Edited May 10, 2012 by SolarPVDesigner Quote
Lee Mac Posted May 10, 2012 Posted May 10, 2012 SolarPVDesigner, Have a read of the Code Posting Guidlines for information on how to format code in your posts. Also, looking at the code you have posted, are you aware that this will overwrite the export file for each Polyline selected? Is this your intention? Lee Quote
SolarPVDesigner Posted May 10, 2012 Posted May 10, 2012 Lee Mac, I will follow the Guidelines from here on out. And Yes I want to overwrite the export file. John Quote
pBe Posted May 10, 2012 Posted May 10, 2012 (setq fn (open "c:/autolisp/infile.txt" "w")) and (close fn); Quote
pBe Posted May 11, 2012 Posted May 11, 2012 Where would the following code be incorporated into the code above? Once I see it done I can grasp it and then look out world!! Thanks pBe and Lee Mac Thanks, (setq thelist [color=blue][b](mapcar (function (lambda ( j) (trans j 0 e))) [/b][/color] (AT:GetVertices (setq e (ssname theobj 0))) [color=blue][b]) [/b][/color] ) HTH Quote
saunambon654 Posted February 21, 2023 Posted February 21, 2023 After export Polylines to file, could I import that file to other drawing with nothing change (include Spline or Arc segments, Layer, color...)? It is like Copy and Paste to Original Coordinates, but instead open DWG file and copy, I can choose that TXT file. Thank you. Quote
devitg Posted February 21, 2023 Posted February 21, 2023 13 hours ago, saunambon654 said: After export Polylines to file, could I import that file to other drawing with nothing change (include Spline or Arc segments, Layer, color...)? It is like Copy and Paste to Original Coordinates, but instead open DWG file and copy, I can choose that TXT file. Thank you. As to not dig at all the topic , would you please, upload all dwg, lsp , and text or csv files? Quote
BIGAL Posted February 21, 2023 Posted February 21, 2023 Using Wblock much easier way to approach this request, all dwg object properties are maintained. Quote
