As title says, I have no idea what I am doing wrong.
In autocad 2008 it shows as smooth, but when I import to 3ds max, it shows as faceted.
I have surtab1 and 2 at 100. isolines at 100. facetres at 10.
any ideas?
When i render in autocad its smooth, but when in max, it renders faceted... aarghhh
your surftab 1 and 2 will control the number of faces(before) in your mesh. Facetres only alters the render and display resolution in autocad and will have no affect on how 3ds views the object. I have very little experience with 3ds so im not sure how you will control this in 3ds.
Is your object a solid, surface, mesh?
HI, yes it's a an oval mirror frame, created using extrude along a path to give the shape, so solid. I have read up on polygons in 3ds max, so maybe that is it? I'm trying to see how i alter that at the minute.
thanks for the reply!!
i think you can do a turbo smooth modifier and it doubles the mesh cells(i think:))
Thanks mr cad64!
I changed the import settings to similar to one of those threads, great help.
It's smoooth now. :-)
I'll be on here to ask more questions soon! :-)
  • 1 month later...
any ideas?
How to make a curved 3d object smooth?
any ideas?
