how to change the arc from concave to convex?
I'm trying hard to overcome this problem.I want to draw the door in plan but the arc is coming in other direction.here is sample drawing.
Drawing1.dwg
Draw the arc in the other direction; use what you had as endpoint previously as Startpoint now.
This is one of the quirks of AutoCAD, arcs only go one way (mostly) :wink:
Oh my .thanks tiger...... it is so easy ...I have wasted half an hour to solve problem
Sometimes there isn't anything to snap to at that end of the arc, so you can still pick the original point, then specify a negative angle
Command: _arc
Specify start point of arc or [[color=red]Center[/color]]: [b]C[/b]
Specify center point of arc:
Specify start point of arc:
Specify end point of arc or [[color=red]Angle[/color]/chord Length]: [b]A[/b]
Specify included angle: [b]-90[/b]
