M Adamson Posted October 23, 2008 Posted October 23, 2008 Can anyone advise how I can automatically trim multiple (sometimes hundreds of lines) to a specific boundary such as a circle or poly line rather than having to trim each one individually? Thanks Quote
ReMark Posted October 23, 2008 Posted October 23, 2008 AutoCAD 2002 right? Do you have the equivalent of Express Tools? If so there was a command called Extrim that I think would fit your criteria. Quote
Commandobill Posted October 23, 2008 Posted October 23, 2008 In Autocad map there is a tool called boundary trim. Other than that I'm not sure. Quote
bonehead411 Posted October 23, 2008 Posted October 23, 2008 Or there's always the FENCE option. Quote
lpseifert Posted October 23, 2008 Posted October 23, 2008 Try here ... you need to register first but it's free Quote
mugshot Posted October 24, 2008 Posted October 24, 2008 i''ll agree on bonehead, trim>select object>f (this you will create an imaginary line bet. the ref point to the trimming objects) then clik2. Quote
