gutter2d Posted February 23, 2012 Posted February 23, 2012 I was using a 3 MB PDF underlay yesterday and zooming/panning/saving operations were very sluggish. BTW, when I attach a PDF underlay, AUTOCAD allows me to snap to the lines in the PDF and even measure them. Since it recognizes those lines, is there an easy way to copy the lines from the PDF into the drawing? Quote
SLW210 Posted February 23, 2012 Posted February 23, 2012 I was using a 3 MB PDF underlay yesterday and zooming/panning/saving operations were very sluggish. BTW, when I attach a PDF underlay, AUTOCAD allows me to snap to the lines in the PDF and even measure them. Since it recognizes those lines, is there an easy way to copy the lines from the PDF into the drawing? No. You might use a PDF to DWG converter, might as well trace it if the snaps are working. That also depends on how recent the PDF is and whether or not it is raster or vector. This is also being moved to its own thread. Here AutoCAD Drawing Management & Output> Copy lines from PDF Underlay to Drawing Quote
