paisis123 Posted February 24, 2012 Posted February 24, 2012 As the title says. How do you Scale the drawing that i have in model space that's currently drawn in MM to INCHES? I'm AutoCAD employee and i still have trouble with scaling. Any help will be appreciated. Quote
ReMark Posted February 24, 2012 Posted February 24, 2012 The scale factor would be 1/25.4 = 10/254 = 0.03937007874015748. Close enough for you? Quote
eldon Posted February 24, 2012 Posted February 24, 2012 There are too many figures there for me. How about drawing a line 25.4 long. Then scale the whole drawing with reference to that line, and the new length is 1 Hope you have not got too many dimensions, because they HATE being scaled Quote
ReMark Posted February 24, 2012 Posted February 24, 2012 And here I thought the OP was looking for precision. Quote
paisis123 Posted February 24, 2012 Author Posted February 24, 2012 Wait i figured it out Can you double check this technique that my coworker showed me? find the measurement of one line of the drawing in this case 35xx mm then find out what that converts to in inches in this case 137.xxx then by drawing a new line on the original drawing at the proper scale that you want, just use the scale command and stretch it to the new point. ReMark, was this a right course of action? Quote
bill_borec Posted February 24, 2012 Posted February 24, 2012 I like precision! Um...quick question...if the OP "works for AutoCAD" why does he/she show ACAD2010 as current version? Might you need to update your profile? Quote
SLW210 Posted February 24, 2012 Posted February 24, 2012 Select objects to be scaled, SCALE command, select base point, Right-Click and select QuickCalc, 1/25.4= select Apply and hit enter. I once had a couple of macros to select all and scale, one for mm to inches and one for inches to mm. Quote
eldon Posted February 24, 2012 Posted February 24, 2012 If you want precision, then I gave you precision. One of the few conversions that does not involve huge numbers of figures, 25.40000000000000000000mm equals 1inch exactly. Quote
rickh Posted February 25, 2012 Posted February 25, 2012 Another option: maybe it's different for autocad vs. civil3d, but I believe -dwgunits in autocad (I know -aecdwgunits in civil 3d) will ask something like "scale objects in drawing?" when you change the units. Select yes and it will scale the objects for you. Quote
Murph_map Posted February 25, 2012 Posted February 25, 2012 I'm AutoCAD employee and i still have trouble with scaling. . Do you mean you work for AutoCAD the company or you work for a private firm to use AutoCAD? Quote
