paisis123 Posted February 27, 2012 Posted February 27, 2012 This is really weird and annoying here is my problem i select all objects Right click>Property's Property's box Comes up but it is blank, and the top selection says there is no selection! Any idea why? and is there a way to fix this? Quote
nestly Posted February 27, 2012 Posted February 27, 2012 Does it happen all the time, or only when you select many objects? If all the time, did you run a registry cleaner recently? Properties Palette blank after selecting objects Quote
paisis123 Posted February 27, 2012 Author Posted February 27, 2012 Only when selecting many objects I tried to increase the selection count to the maximum ~37xxx but i can select half and half of the drawing. Quote
