paisis123 Posted February 29, 2012 Posted February 29, 2012 Sup guys, I need a quick step by step TUT on Merging layers. I have trouble on executing the command. I select the 2 layers that i want merged and press enter and nothing happens. what am i doing wrong? -Jonathan Quote
Dadgad Posted February 29, 2012 Posted February 29, 2012 After selecting the name of the layer which you want to merge, then you will be prompted to select the target layer to which you wish to merge. If you use the Name selection option, then right click after selecting the name of the layer which you wish to merge, then you will get the target layer prompt. Sorry, I had remembered it backwards(above has been corrected), here is how it goes....... Command: LAYMRG Select object on layer to merge or [Name]: Selected layers: Steel. Select object on layer to merge or [Name/Undo]: Select object on target layer or [Name]: ******** WARNING ******** You are about to merge layer "Steel" into layer "0". Do you wish to continue? [Yes/No] : Y Deleting layer "Steel". 1 layer deleted. Quote
Tiger Posted February 29, 2012 Posted February 29, 2012 laymrg select entity on layer that you want to merge select entity on layer you want everything to end up on none of the layers can be the current one. Quote
paisis123 Posted February 29, 2012 Author Posted February 29, 2012 Thank you guys I have failed to account to press [enter] Dumb and stupid mistake on my part. you may throw me under the bus now! Quote
Tiger Posted February 29, 2012 Posted February 29, 2012 To be honest, I failed it too. It took some careful reading on the commandline to understand how the command really worked and what it was asking for... Quote
