Nellie Posted October 24, 2008 Posted October 24, 2008 I'm hoping i've put this in the right place guys but i'm wanting to know how to array a curve. I can't use the normal array command as it's not a circle so soes anyone know a quick way of doing this? Thanks in advance. Quote
dbroada Posted October 24, 2008 Posted October 24, 2008 I'm not sure I understand the question. A curve is just another shape and can be arrayed as normal. Or do you mean array an object along a curve? Quote
Nellie Posted October 24, 2008 Author Posted October 24, 2008 Yes mate, i just need to array along the path of a curve. Quote
dbroada Posted October 24, 2008 Posted October 24, 2008 ah, outside my experience. You can use measure to insert blocks equispaced along a curve. There are probably LISP routines available too but I don't know any other methods. Quote
nocturne00 Posted October 24, 2008 Posted October 24, 2008 Convert any object you wish to array into a block. specify the basepoint of the block at its midpoint(or point on object of your choosing) for this will be the node in w/c measure will snap it to Quote
