nowikovs12 Posted March 4, 2012 Posted March 4, 2012 Hello everyone, I was looking on Google, and couldn't find a clear answer, I want to print my CAD drawing, but when I select DWG to PDF, the largest size it provides is A0. Is there a way to make a custom size within the plotting manager? Thank you Quote
VTI892 Posted March 4, 2012 Posted March 4, 2012 When you select DWG to PDF press Properties (at the right of the printer) go to \User-defined Paper sizes & calibration\Custom paper sizes and press Add. You can create a paper size from scratch or using an existing one Quote
nowikovs12 Posted March 4, 2012 Author Posted March 4, 2012 Thank you VTI892, I found the settings, you made it very clear Quote
BIGAL Posted March 6, 2012 Posted March 6, 2012 Whats more important if your trying to make it real big is playing with the dpi output, you can have a big dpi but small size or large size but smaller dpi. The bottom line is a balance and your pdf's will not get gigantic in terms of disk space. Quote
