Diesel Posted March 8, 2012 Posted March 8, 2012 Is there a way to create a new layer with a new Line Type that has the word power - in the actually line.. I am using Auto-cad LT 2012 Thanks Quote
MSasu Posted March 8, 2012 Posted March 8, 2012 Yes, you can create a linetype that has "POWER" string embedded. Check in your acad.lin file (this store built-in linetype definitions) for "GAS" linetype and use it as a template. Regards, Mircea Quote
bill_borec Posted March 8, 2012 Posted March 8, 2012 Add the following to your ACAD.LIN file, then load the linetype. *POWER_LINE,Power line ----POWER----POWER----POWER----POWER----POWER----POWER-- A,.5,-.2,["POWER",STANDARD,S=.1,U=0.0,X=-0.1,Y=-.05],-.25 C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\UserDataCache\Support Quote
Diesel Posted March 8, 2012 Author Posted March 8, 2012 I have been out of the Cad field for about 4 years so some of this I have forgotten. Where is the acad.lin file located if you would please. Thank you Quote
MSasu Posted March 8, 2012 Posted March 8, 2012 You may try this: *POWER_LINE,Power line ---POWER----POWER----POWER----POWER--- A,.5,-.2,["POWER",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.45 You will find the acad.lin file into your AutoCAD's Support folder. Or, you can create your own LIN file and point to it when load linetype's definition. Regards, Mircea Quote
Diesel Posted March 8, 2012 Author Posted March 8, 2012 Thank you very much guys. I appreciate all of your help... Quote
MSasu Posted March 8, 2012 Posted March 8, 2012 You're welcome! By the way, in my example you may want to adjust the last value (-.45) to match the font you are using for Standard style - to prevent the line to overlap the label on right side. Regards, Mircea Quote
Tankman Posted March 9, 2012 Posted March 9, 2012 Try this lisp file, make any "worded" line you need. LTFly Instructions.zip Quote
