jafooli Posted March 9, 2012 Posted March 9, 2012 hi guys, im after to join two lines into one line. ive got a rad of 10mm then a straight line. dxf as shown, im using Lt so could someone point me in the right direction please temp.dxf Quote
MSasu Posted March 9, 2012 Posted March 9, 2012 Please check the JOIN command - you have there a polyline and a line, so first select the arc shape entity. Regards, Mircea Quote
jafooli Posted March 9, 2012 Author Posted March 9, 2012 when a highlight the pline arc then type join its a unknown command?? Quote
MSasu Posted March 9, 2012 Posted March 9, 2012 Probably the command isn't available in 2004 or is an Express tool (not available in LT). Sorry. Alternatively can use the PEDIT command and his Join option – this will behave differently according with which item you select first. I mean, if start from arc will get directly the edit options, if start from line will be asked first to accept to be converted to a polyline, but the end results are identical. Regards, Mircea Quote
jafooli Posted March 9, 2012 Author Posted March 9, 2012 ok so i highlighted the pline arc first, then PEDIT then JOIN, highlight the two plines and ENTER. ok so far its done this but now is there a way to when I select the line I see a start point and end point of the straight line then the blue box in the middle of the arc which I have just joined to the straight line. can I get rid of the middle blue box? hope that makes sence Quote
MSasu Posted March 9, 2012 Posted March 9, 2012 can I get rid of the middle blue box? I'm afraid that you can't - is the way AutoCAD mark control points. You can disable the grips only globally - see GRIPS system variable. Regards, Mircea Quote
