Everything is stuck
Guest NUBBZ143
I've been working on some assemblies and one in particular has been working fine all day. I got back from lunch, rebooted my computer and now none of my components will move anymore. They're not grounded and none of the constraints have changed since an hour ago. Any suggestions?
Gremlins...I'm sure of it...
Seriously though , If you could pack n' go the assembly and post it it would be easier to troubleshoot.
Guest NUBBZ143
I played with it some more and found out that it's only sticking visually. When i try to drive the constraint that i was using it's showing the degrees of motion moving, but i can't see it on the screen. The driven constraint is under part1 by the way.
Guest NUBBZ143
Tried to upload a zipped pack and go file...think it's too big still
What service pack are you running? I had a problem like this but its disappeared after the latest service pack was installed
