Hi there guys
I'm looking to map layer sets from one set of drawings to another set via VL (inside a script).
The problem for me is I can't find the DXF code 370 ( lineweight ename value ) when using tblnext to get the "LAYER" symbol table parameters. (have changed lineweight with layer manager to be sure)
Is there afurther step I need to include past the tblnext cmd?
Alternately I need the vla commands that interigate the symbol table for lineweight.
(I can't even get the vla-get-freeze to work tho so the code for the collection would be helpful too.)
would anyone have that elusive idea / bit of code ?
Thanks in advance
Matt
  • Replies 35
  • pBe
    13
  • Lee Mac
    7
  • bgerico
    6
  • MSasu
    4
Try using TBLOBJNAME instead:
(entget (tblobjname "LAYER" "0"))
Regards,
Mircea
Thanks Mircea
that worked perfectly :)
I also worked out/borrowed the collection and lineweight using
(vlax-for layers
(vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object)))
   (setq lay_linewt (vla-get-lineweight layers)) ; where default linewt = -3
) ; end for
but need to put in more code to get the result to mean anything
Edited by SLW210
  • 2 weeks later...
Hello everyone,
I am new to this forum. I had the same problem as Matt, I am looking for the DXF code 370 (lineweight ename value) that is assigned to Text or Mtext. I am trying to write a lisp routine that selects all text and mtext and determines if the text lineweight is less than .012". if it is then change it to .012". Here at my company we are having a problem seeing the fonts when plotting if they are less than .012", which is our standard. We found many drawings that contained .000" or .010".
Does anyone have code that would do this sort of routine. Any help would be great.
Thanks, Rick
For both TEXT and MTEXT entities the lineweight is stored on DXF code 370, which is listed when get the associated list by ENTGET. When there is no 370 code, then the lineweight is set to ByLayer.
Regards,
Mircea
(defun c:MTLwt  (/ ss e i)
     (vl-load-com)
     (if (setq ss (ssget "_X" '((0 . "*TEXT"))))
                 (if (< (vla-get-lineweight
                              (setq e (vlax-ename->vla-object
                                      (ssname  ss (setq i    (1- i))))))
                        30)
                       (vla-put-lineweight e 30))
Vanilla
(defun c:MTLwt  (/ ss e a)
                 (setq e (entget (ssname ss (setq i (1- i)))))
                 (cond
                       ((not (setq a (assoc 370 e)))
                        (entmod (append e '((370 . 30)))))
                       ((< (cdr a) 30)
                        (entmod (subst '(370 . 30) a e))))))(princ)
You can however modiy the layer where the text/mtext is currently assigned and change the linewight to 30 and change all text/mtext LW property to bylayer.. (just a thought)
Edited by pBe
Edit formatting....
pBe , I couldn't finish my code before you modified your last post and added Vanilla one , so I should save my code into my toolbox. :lol:
I guess the OP needs the lineweight to be 0.13 and neither 0.12 or 0.30 .
Thanks
One comment, just don’t forget that the lineweight setting is obsolete if the font is TTF.
Regards,
Mircea
Thanks
0.012" [inches] ---> 30mm
Besides, i dont think you can assign floating numbers to DXF 370.
I am sorry , I did not notice the inch mark :oops:
Did not get your idea .:o
Thanks
Regards,
Mircea
I never knew that Mircea. Good point.
Also the need to check for valid values for LW, otherwise it wont do a thing. (i.e. 14 32 invalid values) ;)
Cheers
A minor optimisation:
(defun c:txtwgt ( / a e i s )
   (if (setq s (ssget "_X" '((0 . "*TEXT") (-4 . "<NOT") (-4 . ">=") (370 . 30) (-4 . "NOT>"))))
       (repeat (setq i (sslength s))
           (setq e (entget (ssname s (setq i (1- i)))))
           (if (setq a (assoc 370 e))
No worries tharwat :)
Thanks
0.30 or 1.50 nor 1 12 28
Reference:
quote_icon.png Originally Posted by DXF Reference
330-369 String representing hex object IDs
370-379 16-bit integer value
380-389 16-bit integer value
http://docs.autodesk.com/ACD/2011/ENU/filesDXF/WS1a9193826455f5ff18cb41610ec0a2e719-7a64.htm
Yes. that. ;)
Thank you for WiLeepedia
......(setq s (ssget "_X" '((0 . "*TEXT") (-4 . "<NOT") (-4 . ">=") (370 . 30) (-4 . "NOT>")))).....
Better :thumbsup:
Thanks for the quick reply. Its nice to have this in both versions. The program worked great. This is exactly what we were looking for.
Thanks again.
     (vl-load-com)
                        30)
Vanilla
                 (cond
                       ((< (cdr a) 30)
Thanks again.
Great, good for you bgerico
here's another one
     (vl-load-com)
                           '((0 . "*TEXT") (-4 . "<=") (370 . 30))))
                 (vla-put-lineweight
                       30))
Enjoy :)
