Thanks for all those replies, so here is another question for this routine. If I wanted to add all lines that were also less than .012" but make them .004" could I add it in on this line with a follow up if statement. I guess I would have to separate the two "IF" statement to handle the "TEXT" portion and the "LINE" portion. Is this correct?:
(if (setq ss (ssget "_X" '((0 . "*TEXT")(0 ."LINE")))). Still learning this stuff. Any suggestions?
Thanks, Rick
  • Replies 35
  • pBe
    13
  • Lee Mac
    7
  • bgerico
    6
  • MSasu
    4
sure
(defun c:MTLwt  (/ ss e i)
     (vl-load-com)
                           '((0 . "*TEXT[color=blue],LINE[/color]") (-4 . "<=") (370 . 30))))
                 (vla-put-lineweight
                       (setq e    (vlax-ename->vla-object
                                        (ssname ss (setq i (1- i)))))
                       [color=blue](if (wcmatch (vla-get-objectname e) "*Text") 30 9)[/color])
HTH
pBe,
Note that this filter:
will exclude objects whose lineweight is set to ByLayer, (hence why I use the "" structure) - but then maybe that is what the OP requires.
pBe,
will exclude objects whose lineweight is set to ByLayer.
Odd, cant seem to duplicate that condition Lee :unsure:. It doesnt exclude values less that 30 here in R2009. since -1 & -3 still less than 30. Maybe by using operand ">".
(> -1 30)
nil
T
will give you a different result, what do you think?
Edited by pBe
My apologies, you are right, the relational test does work, even though the DXF 370 group is not present in the return of entget when set to ByLayer - nice to know.
No worries Lee, I learn more from you than any website
Cheers :)
Ok, you guys (Lee & pBe) are giving me great info on this text and line weight problem. I did some more testing after the last thread and found out that the new routine that was sent to me works great still with the text line weight, however, the added code for lines created a small problem. I should have said in my post that I needed all lines that were less than .004" be changed to .004". The new code changed all lines less than .012" and equal to .012" to .004". I didn't see this at first until I tested it on a good drawing. I was testing the routine on a drawing were I added text and lines to with different line weights. My fault. So is this a simple fix, I am sure it is for you guys. Can you send it back to me in Vanilla Autolisp, that Visual Lisp gets me confused. :shock:
Here is the code that was sent to me:
(vl-load-com)
'((0 . "*TEXT,LINE") (-4 . "
(vla-put-lineweight
(if (wcmatch (vla-get-objectname e) "*Text") 30 9))
Try something like this (modifying my earlier post):
(defun c:test ( / a e i s x )
   (if (setq s
           (ssget "_X"
                   (-4 . "<OR")
                       (-4 . "<AND")
                           (0 . "*TEXT") (-4 . "<") (370 . 30)
                       (-4 . "AND>")
                       (-4 . "<AND")
                           (0 . "LINE")  (-4 . "<") (370 . 09)
                       (-4 . "AND>")
                   (-4 . "OR>")
       (repeat (setq i (sslength s))
           (setq e (entget (ssname s (setq i (1- i))))
                 x (if (eq "LINE" (cdr (assoc 0 e))) '(370 . 9) '(370 . 30))
           (if (setq a (assoc 370 e))
               (entmod (subst x a e))
               (entmod (append e (list x)))
Thanks for the new routine, I will check it out tomorrow on some drawings and see what works. You guys are great. Cross your fingers!!!!
Rick
Well in that case (-4 . "]
As for a code, cant get any better than what Lee posted. [Vanilla]
Cheers
Hey Guys, I did some testing this morning and it looks like the routine is almost there. The lineweight text portion of the routine works great. All text less than .012" lineweight including bylayer text is made .012" and all text greater than and equal to .012" lineweight are not changed. So we are good there.
However, the Line linweight portion still has one problem. Here is what works on the Line portion. All line lineweights .004" and greater are not changed and all lines less than .004" are changing to .004". This is good. What i didn't account for are lineweights that are set to "Bylayer". Just like in the text portion all "Bylayer" text lineweight were changed to .012". In the line portion I need any "Bylayer" lineweight also to change to .012". As the routine runs now the "Bylayer" lineweights are changing to .004" also. So can you adjust Lee's (vanilla) routine to make the "Bylayer" lineweights change to .012". This should do it. I hope this doesn't put you guys out. Seems like you all like a challenge.
Thanks, Rick
remove then oops
Didnt read the post long enough to understand the request.... hang on
So if LINE or TEXT/MTEXT is "Bylayer" go 0.12"
If LINE LW less than 0.009 go 0.004"
If TEXT/MTEXT less than 0.012" go 0.012"
(defun c:MTLwt  (/ ss e a j)
     (if (setq ss
           (ssget "_X"
                   (-4 . "<OR")
                       (-4 . "<AND")
                       (-4 . "AND>")
                       (-4 . "<AND")
                       (-4 . "AND>")
                   (-4 . "OR>")
                 (setq e (entget (ssname ss (setq i (1- i))))
                       j (if (eq (cdr (assoc 0 e)) "LINE") 9))
                 (cond
                       ((not (setq a (assoc 370 e)))
                        (entmod (append e '((370 . 30)))))
                       (j  (entmod (subst '(370 . 9) a e)))
                       ((and a (null j))  (entmod (subst '(370 . 30) a e)))
         )(princ)
BTW: what if "ByBlock"? still 0.012" for both LINE and TEXT?
Edited by pBe
Thanks pBe :)
Though, it could be made more concise:
(defun c:test ( / a e i s )
   (if (setq s
           (ssget "_X"
                   (-4 . "<OR")
                       (-4 . "<AND")
                       (-4 . "AND>")
                       (-4 . "<AND")
                       (-4 . "AND>")
                   (-4 . "OR>")
           (setq e (entget (ssname s (setq i (1- i)))))
           (cond
               (   (null (setq a (assoc 370 e)))
               (   (eq "LINE" (cdr (assoc 0 e)))
               (   (entmod (subst '(370 . 30) a e)))
Thanks pBe :)
Indeed , I had one too many vairables not needed. :lol:
Cheers Lee. :thumbsup:
