problems on printing a 3d object into bond paper size?
i have a problem since im printing a 3d object into a bondpaper size the result is always like a rough picture i want to know what will be the proper process on how to print a 3d object into a smooth picture like in a photograpy picture. thanks. im using 2002 version of cad
I think you are referring to a "rendered" photorealistic print.
First you'll have to apply some materials to the object. Then you'll have to place some lights. Follow this up by doing an actual render. AutoCAD does have different levels of rendering (from 'draft' to 'presentation'). Finally, you'll have to save the rendering in a suitable file format. It could be .bmp or .jpg depending on your personal preferences and what you might end up doing with the image file.
