How to filter those dimensions with diameter symbol?With ssget... %%c....
If you are talking about diameter symbols that were added as prefix, then:
(ssget "_X" (list '(0 . "DIMENSION") (cons 1 "%%C*")))
Regards,
Mircea
Mircea,
A minor comment: no need for list/cons:
(ssget "_X" '((0 . "*DIMENSION") (1 . "*%%C*")))
You are right! Thank you for correction.
Regards,
Mircea
Seems to be Case Sensitive... or not??? %%C or %%c - not the same...??? How to work for both c and C?
Please check WCMATCH function's rules for wild characters:
(ssget "_X" '((0 . "*DIMENSION") (1 . "%%[cC]*")))
Regards,
Mircea
(ssget "_X" '((0 . "DIMENSION") (-4 . "") (-4 . "*") (-4 . "not>")))
This is exactly what i needed... Can be made simpler?
Shorter version:
(ssget "_X" '((0 . "DIMENSION") (-4 . "<not") (1 . ",*%%[cC]<>*") (-4 . "not>")))
Also, please add the code markers to your code excerpt.
Regards,
Mircea
