Greendamo Posted March 14, 2012 Posted March 14, 2012 Hi all Can someone please tell me how to get a 3D soid in to Keyshot 3 that is smooth! Ie no obvious facet edges. I have tried everything to my knowledge, FACETRES = 10 etc but every time i open up the model in keyshot it is faceted! Any help guys will be much appreciated. Damian Quote
Bobzy20 Posted March 14, 2012 Posted March 14, 2012 I have the same problem when I import cylinder objects into KeyShot from AutoCAD, I always get the FACETRES lines which make it look rubbish. Quote
lamensterms Posted July 29, 2014 Posted July 29, 2014 You may be able to achieve pretty good results by exporting from AutoCAD to another format. Maybe try export to .SAT. Quote
Titi95 Posted July 29, 2014 Posted July 29, 2014 I often work with Autocad / Keyshot and I always transfer format. IGES for good form. Quote
lamensterms Posted July 29, 2014 Posted July 29, 2014 Thanks for the tip Titi95 - what type/size models do you work with? I am a structural steel detailer in the market for a new rendering program. Quote
Titi95 Posted July 29, 2014 Posted July 29, 2014 As you scored a new post. Keyshot is for small room or small project. For large projects I utlise Lumion Quote
lamensterms Posted May 5, 2016 Posted May 5, 2016 Just follwing up on this old thread. The best method I have found (to get accurate curves) is to import your .DWG into Navisworks with a high faceting factor (Navisworks setting), then export from Navisworks to .FBX. Then import .FBX into Keyshot. I've had a few issues with material mapping, but sometimes accurate curves are more important than accurate materials. Quote
