Finding Special Characters and symbols
I need some help in finding the tool bar or pallete that has the special characters and symbols ( Microns, Center Line, etc.)
ACLT 2012
Thank you.
When in the Mtext Editor, click the @, at the bottom select option Other... will open the Character map.
if the font your using doesn't have the character your looking for check some of the other fonts ...
I must be doing something wrong.
Using Mtext, it just says ...."can not find shell program".
I am clikcing on mtext icon.
height
width
..and then the message shows up.
I used to just type TX. Then configure H and W and then just type.
Can you help me a bit more with some specific steps?
Thank you.
Please verify that the editor for MText entities is set to "Internal"; check the state of MTEXTED system variable - if this list a path, then input "." (dot) and press .
Regards,
Mircea
Thank you . The MText was NOT set. I set it to "." as directed and everything is like it should be. I found the "other" as directed and I was back in business.
Much appreciated. Merci Beaucoup!
Sound good! Avec plaisir!
Regards,
Mircea
Avec plaisir! (With Pleasure)
You should have mentioned the exact problem to begin with, but all is well that ends well.
Ha Ha HA! I'm so dumb at this, I didn't even know what the exact problem was.
Thank you all for the help.
