stevsmith Posted March 14, 2012 Posted March 14, 2012 How do you dimension to and intersection in a dwg? In inventor you can right click and select intersection. sw doesnt seem to have this option. and it has a rather long winded way of doing it. i would like to know how you all do this. Thanks in advance. Quote
khama Posted March 15, 2012 Posted March 15, 2012 ok it is hard to do. First right click on a toolbar. From the list pull up the selection filter toolbar and the quick snaps toolbar. Now you have snaps and selection of type of filter you need. Select what you are trying to snap.. being edge, vertex, faces, bodies etc.. now choose a quick snap function. The only one available is intersection of 2 curves. You can try also horizontal / vertical as well. I can't be bothered using this method. The easiest way is to draw a few construction lines and snap to that. Painful I know, but easier. Quote
stevsmith Posted March 16, 2012 Author Posted March 16, 2012 Yeah, I found that way to be rather tedious. I actually found another way but it's just as long winded. So much so, I have came home and already forgot how to do it. lol. I will post what i done on Monday but it involves the "dim expert" highlight 2 vertices and it creates a sharp which can be snapped to. Quote
shift1313 Posted March 16, 2012 Posted March 16, 2012 How do you dimension to and intersection in a dwg? In inventor you can right click and select intersection. sw doesnt seem to have this option. and it has a rather long winded way of doing it. i would like to know how you all do this. Thanks in advance. is this a .dwg or an a .slddrw file? Quote
stevsmith Posted March 16, 2012 Author Posted March 16, 2012 .slddrw Matt. I'm no longer using inventor, I've got a new job and it's all Solidworks :D:D:D:D:D:D HAPPY DAYS ONCE AGAIN!! Quote
