Hello,
I need to write some text in continuation in different color. I am not getting a way to change the color of some part of the text. Can you please put some light on how this can be achieved.
Thanks in Advance...
Inside the MText editor highlight the part that you want to edit, chouse the color from pop-up list and close the editor. However if the entity is Text this will not be possible.
Regards,
Mircea
I need to make the text entity of different colored, so looking for that,
thanks for your suggestion Mircea...
I think you mean like this? Once in the text formatting mode, select the text which you want to change, then select the color (circled in red), and you're good to go.
Just like described by msasu. :thumbsup:
If you have the patience for it, you could make every letter a different color.
