einsuner12 Posted March 15, 2012 Posted March 15, 2012 Hi! if i'm using polyline it doesnät show any snap points? What seems to be the problem? Thanks! Quote
rkent Posted March 15, 2012 Posted March 15, 2012 I believe you have to use CONVERTPOLY and use the light option. Quote
Dadgad Posted March 15, 2012 Posted March 15, 2012 I believe you have to use CONVERTPOLY and use the light option. Nice one rkent, I've never heard of that before! Quote
einsuner12 Posted March 15, 2012 Author Posted March 15, 2012 If i enter pl command and start drawing i can't get any snap points... Quote
Dadgad Posted March 15, 2012 Posted March 15, 2012 Do you even have your OSnaps enabled? Throwing up a prayer, from way down town! :wink: Quote
einsuner12 Posted March 15, 2012 Author Posted March 15, 2012 with line command it works. osnap is enabled Quote
SLW210 Posted March 15, 2012 Posted March 15, 2012 What does PLINETYPE equal? Try PLINEGEN also. Quote
rkent Posted March 15, 2012 Posted March 15, 2012 Are you trying to snap to lines with a linetype other than continuous, like hidden, dashed, etc.? Quote
CyberAngel Posted March 15, 2012 Posted March 15, 2012 Hi!if i'm using polyline it doesnät show any snap points? What seems to be the problem? Thanks! That's not much to go on. Can you go into more detail about what you're trying to do? Quote
nestly Posted March 15, 2012 Posted March 15, 2012 What does PLINETYPE equal? Try PLINEGEN also. I like where you're going with that.... and I think "snap points" are probably grips. ...also, can you actually select a polyline by clicking on it, if so, what's the Properties Palette say about it? .... as always, posting a sample drawing almost always yields fast/accurate solutions. Quote
einsuner12 Posted March 16, 2012 Author Posted March 16, 2012 Plinetype solved the problem Thanks! Quote
