Lisp for Civil 3D objects - Station from Alignment into a User Defined Property
I was wondering if this was possible at all.
Lisp that will assign the station value from an alignment into a user defined property of a point?
Without coding anything... I can tell you that LISP is severely limited (by default) when accessing or manipulating certain AECC* Objects. One way to know for sure is it drill down with vlax-dump-object Method.
If LISP is unable to access the data you're after, then the only way I know of is to code a custom .NET LispFunction Method which accesses the applicable *TableRecord using Transaction ForRead, the Return the queried data using the LispFunction's ResultBuffer.
HTH
You can not save the allignment details etc into a "point" but a block =point yes.
I have posted code here to get into contours and pointstyle it should be similar to acces the alignment stuff, theres a couple of people chasing this use the "dump" to try and get the alignment "words" you need. Just Search BIGAL
Try this pick an alignment say pick a CIV3d point etc to compare
(setq e (entsel))
(setq obj (vlax-ename->vla-object (car e)))
(vlax-dump-object obj T)
Thanks for the replies. I am going to look into this very soon.
