Mvpart Display Issue
Hi,
Thanks to you, specialy StykFacE, I am getting to like MEP.
Been doing some reading and trying different things to find my ways around.
I have inserted a Valve, and placed it in middle of pipe.
My display configuration is on "MEP Basic 2-line" and Visual style is set to Realistic.
While inserting valve shows like an actual valve, once placed it turns into a sligle line display (like a schematic symbol).
Is there anyway to change this, some it shows the valve better?
Thanks
Change from "MEP Basic 2-line" to "MEP Design". See if that helps. It might not, but try that first.
tried that no luck
It’s wired, if I insert the valve and place it in air (lets say) its ok
Connected one pipe to one side, still fine
As soon as I connect the second pipe, changes to schematic
My pipe Routing Preference is Butt welded and threaded steel tube and my valve is threaded and same size (in this case 40)
