I have changed the color of blockref containing text , mtext ,line etc to paticular color.
But the mtext ht is changed.
(SETQ SS (SSGET '((0 . "INSERT"))))
(SETQ K 0)
(WHILE (< K (SSLENGTH SS))
(SETQ BLK (SSNAME SS K))
(setq CBL (tblsearch "BLOCK" (CDR (ASSOC 2 (ENTGET BLK)))))
(SETQ CBL2 (CDR (ASSOC -2 CBL)))
(WHILE (BOUNDP 'CBL2)
(SETQ EE (ENTGET CBL2))
(SETQ NCL (CONS 62 C))
(SETQ ACL (ASSOC 62 EE))
(IF (= ACL nil)
(SETQ NEWE (APPEND EE (LIST NCL)))
(SETQ NEWE (SUBST NCL ACL EE))
);if
(ENTMOD NEWE)
(SETQ CBL2 (ENTNEXT CBL2))
);end while
(ENTUPD BLK)
(SETQ K (1+ K))
);end while
What could be reason??
the mtext shows paper text ht 2.5 and model text ht is 250.
Edited by kalai
thanks for your reply,
how to correct it
use (vla-put-color itm color)
(defun c:test ( / lst ss bn)
(vl-load-com)
(setq c 3);<--- color
(if (setq ss (ssget '((0 . "insert"))))
     (cond ((and
          (not (member (setq bn (vla-get-EffectiveName
                                        (vlax-ename->vla-object
                                              (ssname  ss
                                                    (setq i (1- i))))))
                       lst))
          (setq lst (cons bn lst))
          (vlax-for
                 itm  (vla-item
                            (vla-get-blocks
                                  (setq aDoc (vla-get-ActiveDocument
                                                   (vlax-get-acad-object))))
                            bn)
                      (vla-put-color itm c))
[color=blue](if lst
   (foreach nm lst
          (command "_attsync" "_name" nm)))
[/color]      (vla-regen adoc acActiveViewport)
Entmod and Annotative textstyle just doesnt work is all :)
Edited by pBe
Attsync
Thank you so much,
It works well
Alrighty then.. But did you understand the code? or would you rather have us modify yours to work with vla-put-color ?
yes i understood
Good for you kalai.
Glad i could help. :)
Hi if the block has attributes ,Attribute text color doesnot change
Attsync
[see updated code]
