Hi there,
I'm freshly minted AutoLISP noob here. My boss has asked if I could write a LISP that would take a dimension like 10,000 and fix it to look like 10 000 instead. It's been a great little exercise, stretching my skills, but I've hit a roadblock I can't figure a way around.
I've converted the dimension into a list which is ready to be turned into a string, but I just can't seem to MAKE it do that. I've tried STRCAT but I keep getting errors.
Can anyone help? I'm sure I can turn it into an ENTMOD and finish the rest but I just need this part figured out. It needs to be without () or "" marks in it.
Thanks! Here's what I've done,
(defun c:DIMCHG ()
(defun GetDim ()
(setq DIMEN (car (entsel)))
(setq OLDDIMEN (entget dimen))
(setq CHANGE (assoc 42 OLDDIMEN))
(setq CHANGE2 (cdr CHANGE))
(setq CHANGE3 (fix CHANGE2))
(setq DIMLTH (strlen (itoa CHANGE3)))
(setq CHANGE4 (itoa CHANGE3))
) ;End GetDim
(defun BreakItDown ()
(setq POSITION 1)
(setq BrkDwn nil) ;remove when finished coding
(repeat DIMLTH
(setq BrkDwn (cons (substr CHANGE4 POSITION 1) BrkDwn))
(setq BrkDwn (cons " " BrkDwn))
(setq POSITION (+ 1 POSITION))
) ;End repeat
) ;End BreakItDown
(defun ReAsmbl ()
(setq RSMBL nil)
(while BrkDwn
(cond
((= POSITION 4)
(setq RSMBL (cons " " RSMBL))
(setq POSITION 1)
((= (car BrkDwn) " ") (setq BrkDwn (cdr BrkDwn)))
((/= (car BrkDwn) " ")
(setq RSMBL (cons (car BrkDwn) RSMBL))
(setq POSITION (+ POSITION 1))
) ;End Cond
) ;End While
) ;End ReAsmbl
(defun ltos ()
(setq gfile (open "acad.grp" "w")) ;open a file on disk
(write-line RSMBL gfile) ;print list to file
(close gfile) ;close file
(setq gfile (open "acad.grp" "r")) ;open file
(setq strname (read-line gfile)) ;read list from file
strname ;return converted list
(GetDim)
(BreakItDown)
(setq POSITION 1)
(ReAsmbl)
(vl-princ-to-string Rsmbl);I got this from the web, but it still doesn't look right
Maybe, try this :
(defun c:dimch ( / dimss n dim dimval d dimvalstr dimvalstrnew )
 (setq dimss (ssget '((0 . "DIMENSION")) ))
 (repeat (setq n (sslength dimss))
   (setq dim (ssname dimss (setq n (1- n))))
   (setq dimval (cdr (assoc 42 (setq d (entget dim)))))
   (setq dimvalstr (rtos dimval))
   (setq dimvalstrnew (vl-string-translate "." " " dimvalstr))
   (entmod (subst (cons 1 dimvalstrnew) (assoc 1 d) d))
M.R.
Maybe, try this :
M.R.
WTF... I'm trying to understand half of what you did and I'm afraid it'll take me a while to study that and understand it... You've got the gist of what I'm trying to do. I'm trying to round it so that no decimal places comes on board. And it's broken in groups of three... for example a dimension showing:
9785642.34 would become 9 785 642
I'm afraid my coding is still really basic as I haven't quite mastered anything in autolisp yet... Yours is like AutoLISP wizardry.
Silvercloak
Oh COOL, I think I'm getting it, you used selection sets. Very ingenious, I never thought of doing it this way. Although, I've never heard of vl-string-translate. I think I'm getting the idea of what you're trying to do though.
I really like how much more secure and tidy this way is. Thank you! Could you show me how to break the dimension down into groups of three without decimal places?
This is quickly written, no doubt there's a better way to add the separators:
(defun c:fixdim ( / e i s x ) (vl-load-com)
   (if (setq s (ssget "_:L" '((0 . "DIMENSION"))))
       (repeat (setq i (sslength s))
           (setq e (entget (ssname s (setq i (1- i)))) x 0)
           (entmod
               (list (assoc -1 e)
                   (cons 1
                       (vl-string-left-trim " "
                           (vl-list->string
                               (reverse
                                   (apply 'append
                                       (mapcar
                                           (function
                                               (lambda ( c )
                                                   (if (zerop (rem (setq x (1+ x)) 3))
                                                       (list c 32)
                                                       (list c)
                                           (reverse (vl-string->list (rtos (cdr (assoc 42 e)) 2 0)))
Note that all of the solutions so far are using a Dimension Text Override, hence the Dimension value will not be updated when the Dimension is modified.
Ideally, the Dimension Style needs to allow a thousands separator option.
           (entmod
               (list (assoc -1 e)
                   (cons 1
                       (vl-list->string
                           (reverse
                               (apply 'append
                                   (mapcar
                                       (function
                                           (lambda ( c )
                                                   (list c 32)
                                                   (list c)
You rock!!! That's exactly what I'm shooting for. Thank you, now I'm going to go over it and learn how you did it. Thanks again to everyone who helped, feel free to add your ideas as well. I want to learn and get better.
Silvercloak
You're welcome Silvercloak - if you have any questions about the code, just ask.
BTW, I've updated my above post and code to trim leading spaces for dimension values
Another way, no code needed:
- To set number formats in Windows, go to
Control Panel -> Region and Language -> Formats [tab] -> Additional Settings and set Space for Digit grouping symbol.
- In AutoCAD, open DimStyle dialog box, edit your Dimstyle and, in Units tab, set Units Format to Windows Desktop.
I knew there must be a better way than Text Override - nice one Stefan :thumbsup:
Hmm, I can't do that here with Windows XP and AutoCAD 2010. Not that I can see anyways.
Silvercloak
@Silvercloak:
You might want to read the forum Code Posting Guidlines and edit your first post to frame your code.
Ok, will do. And text override was exactly what I was shooting for. I just didn't think this little exercise would get this complicated.
Silvercloak
All I managed after Lee is :
(defun 3digspace ( str len / k kk kkk 3dig stdig newstr )
 (setq newstr "")
 (setq k (fix (/ (float len) 3.0)))
 (setq kk (rem (float len) 3.0))
 (if (eq kk 0.0) (setq k (- k 1)))
 (setq kkk 0)
 (repeat k
   (setq kkk (1+ kkk))
   (setq 3dig (substr str (+ (- len (* kkk 3)) 1) 3))
   (if (eq k kkk) (setq stdig (substr str 1 (- len (* kkk 3)))))
   (setq newstr (strcat " " 3dig newstr))
 (setq newstr (strcat stdig newstr))
 newstr
(defun c:dimch ( / dimss n dim dimval d dimvalstr dimvalstrl dimvalstrnew )
   (setq dimvalstr (itoa (fix dimval)))
   (setq dimvalstrl (strlen dimvalstr))
   (setq dimvalstrnew (3digspace dimvalstr dimvalstrl))
M.R.
Edited by marko_ribar
Silvercloak
Space symbol may not be available in the popup list for settings Digit Grouping Symbol. Try to type it. Just click on the edit box and press Space then Apply.
I can't test in AutoCAD 2010. Do you have Windows Desktop option for Units Format?
Ah yes, apparently I do.
DIMLUNIT 6 to quote help "Microsoft Windows Desktop (decimal format using Control Panel settings for decimal separator and number grouping symbols)" normal 2
