GCarr78 Posted March 23, 2012 Share Posted March 23, 2012 To all (using AutoCAD 2010), I've searched the forums and I haven't seen this problem mentioned. So here it goes. I have a attributed block with multiple attributes (called pkey). In some cases these block attributes will the same values save for one, "Total". example: pkey #1 Value AA, Value BB, Value CC, Total 20 pkey #2 Value AA, Value BB, Value CC, Total 30 Is there a way by which I can have AutoCad group these blocks together (when extracted into a table for example) and have the SUM of those "Totals" added together to produce a result such as: Value AA, Value BB, Value CC, Total 50. I've explored using fields, but I don't think they work in this case, unless I'm using them wrong. Any help would be great! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 26, 2012 Share Posted March 26, 2012 Using lisp it would be pretty simple for all blocks "Pkey" add the "Total" up and put somewhere, maybe post a dwg of what you would like Table, text, Attribute etc Quote Link to comment Share on other sites More sharing options...
Dadgad Posted March 26, 2012 Share Posted March 26, 2012 I should think that you could do this using DATA EXTRACTION too. Quote Link to comment Share on other sites More sharing options...
