addesigns Posted March 23, 2012 Posted March 23, 2012 Is there a way to make multiple object flip on themselves? I would like to find a way to rotate multiple objects, but in actuality I want tmen to stay where they are but just rotate 180 and not based on a base point Quote
rkent Posted March 23, 2012 Posted March 23, 2012 Well do you want to mirror or rotate? If mirror pick a base point in the middle of the objects and answer yes when asked if you want to erase source objects. If rotate, then rotate them. Maybe you are asking for something else, if so post a small example. Quote
addesigns Posted March 23, 2012 Author Posted March 23, 2012 I guess it doesnt matter to me since both commands will do the job Im looking for. Im looking to rotate multile objects (Receptacles) in their center so I dont have to rotate each one individually and then move it into position Quote
ReMark Posted March 23, 2012 Posted March 23, 2012 There are custom lisp routines that will rotate multiple blocks based upon their insertion points but multiple objects? What would be the base point for each object? Quote
addesigns Posted March 23, 2012 Author Posted March 23, 2012 Yeah, sorry i meant to say they are blocks. It would be easier to place them where I may and rotate them to the corresponding wall from their base point Quote
nestly Posted March 24, 2012 Posted March 24, 2012 How about a dynamic block? Yes ..... with an "Alignment parameter" Quote
Bogbadbob658 Posted March 24, 2012 Posted March 24, 2012 How about a dynamic block? Wouldn't you still need to select all the blocks individually? Do all the blocks have the same rotation and have the same name? Quote
