helpme Posted March 24, 2012 Posted March 24, 2012 HI all is it necessary to set limits before starting the drawing.What is the steps to do before we start drawing a floor plan. Quote
MSasu Posted March 24, 2012 Posted March 24, 2012 The only reason you will want to define limits is if you are willing to use grid for your drawing. Other you can skip this step. For the second question I will say to load required linetypes, create layers for drawing elements, define text and dimension styles. Next create your axis grid. Draw everything at 1:1 scale and use Paper Space to fit drawing on the desired sheet. Regards, Mircea Quote
the ber Posted March 24, 2012 Posted March 24, 2012 You do not need to set limits. Just start drawing. You should probably use one of the supplied templates (files with extension ".dwt") that matches your units (imperial or metric). As for what steps to take: that covers quite a bit of ground. Can you tell us what level you are at in AutoCAD? Quote
ReMark Posted March 24, 2012 Posted March 24, 2012 My templates have preset limits that I established when creating them otherwise I seldom, if ever, change my Limits. Quote
Dadgad Posted March 25, 2012 Posted March 25, 2012 I haven't used limits in the 4 years I've been using the program, just had to look up what they do, but I don't use the grid, perhaps if I did, I would. Quote
rkent Posted March 25, 2012 Posted March 25, 2012 Limits are unnecessary. Create some layer names that make sense, set Polar or Ortho on and start drawing the lower left corner of your plan at an even coordinate number, like 100,100 or whatever you find works for you. Quote
MSasu Posted March 25, 2012 Posted March 25, 2012 Also, you will do yourself a favor if after setting those drawing features will save the drawing as a custom template (DWT); revise it as you gather experience with this kind of drawings. Regards, Mircea Quote
JD Mather Posted March 25, 2012 Posted March 25, 2012 I don't use limits - never have. (been using AutoCAD since '87 of the last century) There was a time in the last century where maybe using limits would speed things up working on smaller areas of a large drawing with zooms. (you used to get a cup of coffee while waiting for a zoom to complete) Quote
