I am talking about this property
To overide this property on dimensions please check this thread.
Regards,
Mircea
  • Replies 43
  • MSasu
    14
  • pBe
    10
  • jan_ek
    10
  • Lee Mac
    4
Posted Images
Will it be fine. Will there be the unexpected errors.
(defun a_sc (/ dims sc)
(vl-load-com)
(setq dims (car (entsel "\nPick Dimension line: ")));
(setq sc (vla-get-ScaleFactor (vlax-ename->vla-object dims)))
Your code works well on my station; the only correction that I can suggest is to add a protection for missed/wrong selection:
(defun a_sc ( / dims sc)
(vl-load-com)
(prompt "\nPick Dimension line... ")
(if (setq dims (ssget "_:S:E" '((0 . "DIMENSION"))))
 (setq sc (vla-get-ScaleFactor (vlax-ename->vla-object (ssname dims 0))))
Regards,
Mircea
Another, should you wish to use Vanilla AutoLISP:
;; Get DimScale  -  Lee Mac
;; Returns the DimScale for a supplied Dimension Entity
;; dim = Dimension entity
(defun _getdimscale ( dim / _override->dxf )
   (defun _override->dxf ( lst / x1 )
       (if (setq x1 (assoc 1070 lst))
           (cons
               (cons (cdr x1) (cdar (setq lst (cdr (member x1 lst)))))
               (_override->dxf lst)
   (cond
       (   (cdr (assoc 40 (_override->dxf (cdadr (assoc -3 (entget dim '("ACAD"))))))))
       (   (cdr (assoc 40 (tblsearch "DIMSTYLE" (cdr (assoc 3 (entget dim)))))))
Test Function:
(defun c:test ( / s )
   (if (setq s (ssget "_+.:E:S" '((0 . "DIMENSION"))))
       (_getdimscale (ssname s 0))
