Jingqg1979 Posted March 26, 2012 Posted March 26, 2012 Hi All, When I open a .dwg file, 'Missing SHX Files' dialogue pops out. I checked the box 'Always perform my current choice', and clicked 'Ignore the missing SHX files...'. Then .dwg opened, but all text information were not displayed. I closed the .dwg, and reopen again, but this 'Missing SHX Files' does not pop out again. How to get this 'Missing SHX Files' dialogue back? Please see the attachment. Thank you! Quote
nestly Posted March 26, 2012 Posted March 26, 2012 Tools > Options > System > Hidden Message Settings Quote
dbroada Posted March 26, 2012 Posted March 26, 2012 Tools > Options > System > Hidden Message Settingshow did you find that?? (or what were you looking for when you found that) Quote
Jingqg1979 Posted March 26, 2012 Author Posted March 26, 2012 I am using DWG TrueView 2011. There is no such option. What should I do? Quote
gdavila911 Posted September 16, 2013 Posted September 16, 2013 found a solution that worked for me. Im using windows 7 PRO. It looks like the settings are stored in each user profile, so, the long and easy is to reload the user profile, or reimage the computer. The short and easy is to delete the profile.aws file that is stored here: DWG 2013 C:\Users\user_name\AppData\Roaming\Autodesk\DWG TrueView 2013\R10\enu\Support\Profiles\Unnamed Profile\profile.aws DWG 2011 C:\Users\user_name\AppData\Roaming\Autodesk\DWG TrueView 2011\R8\enu\Support\Profiles\Unnamed Profile\profile.aws If you have prevous versions installed, then probably you will need to delete the file in both folders. If delete just the file doesnt work, delete all the contents of the Profiles folders for each version installed. Please let me know if this works for you. Thanks. Quote
