Lee Mac, I have block named $AUDIT_BAD_BLOCK_RECORD1 that cannot be removed i.e it comes back after audit. What can I do about it? Any ideas?
Block is empty...
Refer: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=12056161&linkID=9240617
Also, have you tried WBLOCK'ing the entire drawing?
The following simple LISP provides a quick way to do this:
(defun c:wba ( / dwg fnm tmp )
   (setq fnm
       (strcat
           (getvar 'dwgprefix)
           (cadr (fnsplitl (getvar 'dwgname)))
           "_wblock"
   (if (findfile (setq dwg (strcat fnm ".dwg")))
           (setq tmp 1)
           (while (findfile (setq dwg (strcat fnm "(" (itoa (setq tmp (1+ tmp))) ").dwg"))))
   (command "_.wblock" dwg "*")
  • Replies 23
  • ibach
    8
  • Lee Mac
    5
  • OTRT
    4
  • dbroada
    3
I have, and it helped, but than I had to use paperspace pages from the old dwg (a hell a lot of them) that i cannot redraw manually, when I imported them, all went to old error. So the error is somewhere in paperspace, but I do not know where... There are 100+ A0 pages...
... when I imported them, all went to old error. So the error is somewhere in paperspace, but I do not know where...
To clarify: what is the error message that you receive?
no message at all.
When I import paper space pages from the old dwg i get $AUDIT_BAD_BLOCK_RECORD1 reappearing in drawing after audit, that's why i know the error is in pspace in old dwg.
After AUDIT i get "no errors found". (Of course, old dwg was purged of $AUDIT_BAD_BLOCK_RECORD1 before importing layouts.)
Edited by ibach
