Hello
Just a quick question. Is it possible to load a lisp routine from a web site instead of a network drive? I know i can load it from c: or a network drive (LOAD "lispfile.lsp") but is it possible to load it from a web site? (LOAD www.abcd.com/lispfile.lsp) or something like that. If yes then could you please let me know how? or what is the code
Regards
Fred
To be able to access the file, you will need FTP access to the site. But still I’m not sure that can be done directly with LOAD function. An alterative will be to use a command line FTP client and create a temporary copy of the file to your hard-disk, load it from there and remove it. This way you will be able also to supply a username/password.
Regards,
Mircea
Try this
1.make point to point conection from comp1 to comp2. This a standart conection from windows wizard conection
2. When you establish a conection with comp2 the windows will know ( add) comp2 in local network. Does no matter that comp2 is on the end of the world
3. When you type ( load "\\192.168.........\\......\\.....\\lispfile.lsp") the autocad will load the routine
4. You can add it in win startup sute
This procedure working, because i am using it every day
