DODGE Posted March 27, 2012 Posted March 27, 2012 Hi Guys Just a dumb question. In some of my drawings I need to hatch in colour, I usually pick a colour then change it to a shade I like. The problem I have is after I hatch the item, wall or whatever, I may go to use the same hatch colour again on a different part of my drawing and I can never find exactly the same hatch colour again, especially when I have used a completley different hatch pattern since using the colour hatch. Quite often when you go to use a hatch, the last one you used is there but not when you have used different ones in between. You used to just be able to double click a hatch in your drawing and the hatch dialog box would appear then you could just hatch away using the same one. I can't seem to do this in 2012. Is there anyway of getting this back? Thanks Guys Dodge Quote
MSasu Posted March 27, 2012 Posted March 27, 2012 There is a button named "Inherit Properties" inside Hatch dialog - that will allow you to clone the features from an existing hatch; for color you may use Match Properties (chouse only color from Properties). But I have one question, you are using arbitrary colors for items? Wouldn't be better to establish a standard? Regards, Mircea Quote
