RobDraw Posted March 29, 2012 Posted March 29, 2012 I have to modify hundreds of VAV tags and I am getting this warning for each one. Is there a way to turn off that warning temporarily turn off all warnings? Quote
RobDraw Posted March 30, 2012 Author Posted March 30, 2012 This actually turned out to be a lot less annoying than it was when I first started. If you edit the tag, (which is reading the mark value), at the tag as opposed to using the properties box to edit the mark value, the warning box closes itself when you continue doing you work. If you do it through the properties box, you have to close it manually. Quote
Lee Roy Posted April 2, 2012 Posted April 2, 2012 Custom field in the VAV family with a custom tag, was my cure. Then I don't care what the Mark Value is, cause I'm not using it. Quote
