Somebody can give me an example of a lisp file that take the value of a variable and create a txt file on a especific place defining by the user, with 10 lines in each one of them begins with what is in the variable, followed by a text already done.
Thanks for your help.
  • Replies 31
  • SCaldeira
    12
  • MSasu
    11
  • pBe
    8
  • Tiger
    1
What is the variable value?
-String
-Real
-Integer
-Point list
Is this an assignment of some sort? It sounds like it from your post...
the variable value is String.
Check
And this?
Is that after 10 lines you'll be prompted for another file name?
Show us an example of the resulting text file
:lol:
an example: I put "ABC" into a variable and the result is a text file with 10 lines:
ABCtextexampleline1
ABCtextexampleline2
ABCtextexampleline3
ABCtextexampleline4
ABCtextexampleline10
ABCtextexampleline1......
I understand that SCaldeira, What i'm trying to get from you to tell us is what's the source of this ABCexampleLine1 etc....?
Say you already have ABC, where would the other 10 values comes from? is it from a Selected Text/Mtext entity?
And right after you have the 10 string values, then what happens next? does the progam ends when you reach 10 lines and start over again?
You need to be clear so this thread wont drag-on to 5 pages and what-not. :)
The text already exists and is always the same but different from line to line.
You mean that you are looking to access the file and append a suffix string to each line?
Regards,
Mircea
The title of the thread ask to create a file...
So, you should:
  • open the file in read mode - OPEN,
  • parse each line until the end of file (nil) - WHILE & READ-LINE,
  • append the suffix to each line - STRCAT,
  • store those line into a list - APPEND,
  • when done, close the file - CLOSE,
  • open the file in write mode - OPEN,
  • parse the said list and record the items to file - FOREACH & WRITE-LINE,
  • when done, close the file; this will save it also - CLOSE,
Regards,
Mircea
Thanks, Mircea.
Best Regards.
Now it makes sense.
I guess i'm asking the wrong questions then. :)
@SCaldeira: You're welcome!
If you will encounter issues with this code, just post here what you have written for further help. Don't forget to close the file when finnished accessing it.
Regards,
Mircea
I was also confused by the title of the thread.
Regards,
Mircea
I tried to do so but does not work. Can you help me find the error?
lisp code:
(defun C:d2 ( )
(setq DCL (load_dialog "d2")) ;
(new_dialog "CARTA2" DCL)
(action_tile "IDCarta" "(setq NCarta (get_tile \"IDCarta\"))")
(action_tile "25M" "(setq Escala 25000)")
(action_tile "10M" "(setq Escala 10000)")
(action_tile "5M" "(setq Escala 5000)")
(action_tile "accept" "(done_dialog)") ;
(action_tile "cancel" "(setq NCarta nil)(done_dialog)")
(start_dialog) ; Inicia
(unload_dialog DCL) ;
(setq lspdir "E:\\CartasTXT\\")
(setq txtfile (strcat lspdir "notes"))
(setq fichTXT (open (getfiled "Defina o nome e a localização do ficheiro TXT da carta." txtfile "txt" 1) "w"))
(prin1 (type fichTXT))
(if (= Escala 25000) (
(write-line (strcat NCarta "-your choice is 25000, line1") fichTXT)
(write-line (strcat NCarta "-your choice is 25000, line2") fichTXT)
(write-line (strcat NCarta "-your choice is 25000, line3") fichTXT)
;......an so on
(close fichTXT)
(if (= Escala 10000) (
(write-line (strcat NCarta "-your choice is 10000, line1") fichTXT)
(write-line (strcat NCarta "-your choice is 10000, line2") fichTXT)
(write-line (strcat NCarta "-your choice is 10000, line3") fichTXT)
;......an so on
(close fichTXT)
(if (= Escala 5000) (
(write-line (strcat NCarta "-your choice is 5000, line1") fichTXT)
(write-line (strcat NCarta "-your choice is 5000, line2") fichTXT)
(write-line (strcat NCarta "-your choice is 5000, line3") fichTXT)
;......an so on
(close fichTXT)
dcl code:
/* Dialog Box: carta2 */
CARTA2: dialog { label = "Escala da Carta";
:radio_button {key = "25M"; label = "Carta 1:25000"; }
:radio_button {key = "10M"; label = "Carta 1:10000"; }
:radio_button {key = "5M"; label = "Carta 1:5000"; }
spacer;
:edit_box { label = "ID da Carta "; key = "IDCarta"; width = 7; }
spacer;
ok_cancel;
I have rewritted the code with COND. Also is better to validate if user supplied a name for the new file prior to attempt to access it.
(defun C:d2 ( / [color=red]DCL NCarta Escala lspdir txtfile fichTXT[/color] )
[color=red] (if (and NCarta[/color]
[color=red]          Escala[/color]
[color=red]          (setq fichTXT (getfiled "Defina o nome e a localização do ficheiro TXT da carta."[/color]
[color=red]                        txtfile "txt" 1)))[/color]
[color=red]  (progn[/color]
  (setq fichTXT (open fichTXT "w"))
[color=red]   (cond[/color]
   ((= Escala 25000)
    ;......an so on
   ((= Escala 10000)
    ;......an so on
   ((= Escala 5000)
    ;......an so on
[color=red]   )[/color]
(close fichTXT)
If you want to use IF then should not forget to envelop the expressions with PROGN:
                               ;......an so on
Also, I will let the CLOSE call outside "conditioned" code to ensure that the file is closed.
Regards,
Mircea
That's right. Fantastic.
Thank you Mircea.
:D :D :D :D
You're entirely welcome!
Regards,
Mircea
